dankicksass Posted December 5, 2014 Share Posted December 5, 2014 Pricing may vary. Link to comment Share on other sites More sharing options...
Comanche County Posted December 7, 2014 Share Posted December 7, 2014 The ZJ steering box has a quicker ratio too and is bolt in. I just bought one myself after reading that others here have done it. I've yet to have time to install it but have read good reviews.does it matter what year its from? It doesn't matter what year or model as long as it is a ZJ. Yes it does. Some of the early 92 models did not have the 12.7 quick ratio steering. To be sure, get one from any 93-98 model. Engine does not matter. Sounds interesting, so ALL 93-98 ZJ's will have the quicker steering? is this a true bolt in without any mods ? or is it like installing the durango box? in which you have to modify it a bit. Some 96' Limited ZJs had a speed sensitive steering system to firm up the steering feel at highway speeds. I believe the gearbox is the same though. just sayin..... Link to comment Share on other sites More sharing options...
dankicksass Posted December 8, 2014 Share Posted December 8, 2014 I have a ZJ quick ratio box sitting in a box, I was going to use it but I put a Durango box in instead. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 8, 2014 Share Posted December 8, 2014 That's nice. Thanks for sharing. :thumbsup: Link to comment Share on other sites More sharing options...
johnj92131 Posted December 9, 2014 Share Posted December 9, 2014 If the ZJ quick ratio steering box is a 12.7 ratio, what is the ratio for the stock MJ/XJ steering box? How much difference does it make. Meaning the stock steering is XX turns, lock to lock. With the ZJ box, it is YY turns, lock to lock? Is there another plug and play quick(er) ratio box? Like from a Camaro or Firebird? It is time for me to replace front end components on this 250K old street driven truck. What are the prefered sources for new tie rod ends and ball joints? Not looking for CRAP (Chinese Replacement Auto Parts), but reasonably priced would be good. Thanks, Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 9, 2014 Share Posted December 9, 2014 ZJ steering ratio is 12.7:1 as opposed to the XJ/MJ's 14:1. You can do the math for the rest. Makes a difference, both in tight quarters and on the road. Camaro or Firebird owners grab the ZJ box because the ratio is quicker than any GM stock box. http://www.chevelles.com/techref/ftecref29.html Link to comment Share on other sites More sharing options...
Comanche County Posted December 9, 2014 Share Posted December 9, 2014 Be careful buying a new or reman box from some of the auto part chain stores. My local auto zone and advance list the same part number for a ZJ and XJ box. Link to comment Share on other sites More sharing options...
big66440 Posted December 9, 2014 Share Posted December 9, 2014 And rockauto lists the same part numbers for the 89 MJ as well as for the 94-98 ZJ's :hmm: I would rather go pull one from the J.Y and match the alpha code to be 100% sure you're getting the quick ratio box. Link to comment Share on other sites More sharing options...
husky410ohio Posted December 17, 2014 Share Posted December 17, 2014 The Tie rod parts I installed from NAPA are: ES-2079-S Tie rod adjmnt/sleeve $15.57 269-2788 Inner-otrtie rod end $37.76 DS1312 Left inner tie rod end $32.50 Link to comment Share on other sites More sharing options...
cbreiter Posted December 18, 2014 Share Posted December 18, 2014 I'm looking to swap out my steering box to the quick ratio one. Does the pump switch over too? Just wondering, Cause I was working on swapping out my sway bar, when I noticed that my steering box was leaking, and the pully has a small piece gone out of it on the pump. Anyone know what hoses are best? Link to comment Share on other sites More sharing options...
husky410ohio Posted December 18, 2014 Share Posted December 18, 2014 I have the original steering box with a drop pitman arm and a new GM style pump from Allstar with Detroit Speed mount. The pressure hose I made at work on the hose crimp machine. The hydraulic hose is rated 9000 PSI. I purchase fitting adapter from Summit to go on steering box port to SAE thread. I like that the allstar pump pulley has holes so that the pump can be installed/removed without removing the pulley. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 18, 2014 Share Posted December 18, 2014 I put in an 04 Wrangler pump when I did the ZJ box. It also has the holes in the pulley. Most of the newer Saginaw TC pumps did. Link to comment Share on other sites More sharing options...
cbreiter Posted December 18, 2014 Share Posted December 18, 2014 I guess I should have said the truck is a 4.0 litre, 2wd. I'm mainly looking for bolt on junkyard swaps. Hornbrod, did you swap over the lines with the new pump? And was it a direct bolt up? I guess I could just replace the pulley on mine, but it has a loud whine all the time, I put some Lucas power steering conditioner in it, and it's some quieter, but it bugs me and I don't want it to go out on me. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 18, 2014 Share Posted December 18, 2014 I got the pump from a rolled 04 Wrangler pump in 05, so the pump was almost new. Used the existing hoses that were on it. It was a direct bolt-on for me because I have the 01 intake manifold and 97+ power steering bracketry. It probably won't be a direct bolt-on for your setup. Link to comment Share on other sites More sharing options...
cbreiter Posted December 18, 2014 Share Posted December 18, 2014 What would be a good option for me that would be a bolt on? Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 18, 2014 Share Posted December 18, 2014 What would be a good option for me that would be a bolt on? I did this years ago, and now that I think back, I did use my stock 91 pump and bracketry originally after I changed out the steering gear. Later on when the pump started to leak I added the 97 and up bracketry and the new pump. The only difference in the pumps was a slight takeoff angle difference on the return hose nipple, so the 04 Wrangler pump option should work just fine on your setup too. The Saginaw TC pumps were used on many Jeep and GM vehicles and there are subtle differences, but they are all basically the same physical configuration. Link to comment Share on other sites More sharing options...
cbreiter Posted December 19, 2014 Share Posted December 19, 2014 Alright! I'll see what I can find the next time I'm at the wreckers. Sorry for kinda hijacking the thread. Link to comment Share on other sites More sharing options...
cbreiter Posted March 15, 2015 Share Posted March 15, 2015 Got myself a newer pump today with what looked like fairly new hoses. Hope it fixes my leaks up! Link to comment Share on other sites More sharing options...
