comanche32 Posted August 3, 2014 Share Posted August 3, 2014 my dash lights stopped working so I replaced the dimmer switch and they still don't work. I don't know if the problems are related but my cd player won't light up or turn on at all. I could get it to eject a cd but not take a cd without forcingĀ it. is there a fuse that controls the dash lights and the radio or what else could it be thanks Link to comment Share on other sites More sharing options...
Dando Posted August 3, 2014 Share Posted August 3, 2014 Do your brake lights and taillights work? Link to comment Share on other sites More sharing options...
comanche32 Posted August 3, 2014 Author Share Posted August 3, 2014 just went and checked headlights and brake lights work. corner lights tail lights and dash lights and radio don't Link to comment Share on other sites More sharing options...
Dando Posted August 3, 2014 Share Posted August 3, 2014 Check the fuse for the tail lights, it is built so thT when your tailights go out it shuts down power to your dash lights to warn you about the rear lights being you can't see them Link to comment Share on other sites More sharing options...
88ComancheMitch Posted August 3, 2014 Share Posted August 3, 2014 Check the fuse for the tail lights, it is built so thT when your tailights go out it shuts down power to your dash lights to warn you about the rear lights being you can't see them Quoted for truth, same thing happen to me. The trailer wiring was messes up. Caused it to blow the fuse Link to comment Share on other sites More sharing options...
comanche32 Posted August 3, 2014 Author Share Posted August 3, 2014 I will check that fuse I have mine wired up for trailer also Link to comment Share on other sites More sharing options...
comanche32 Posted August 3, 2014 Author Share Posted August 3, 2014 radio fuse and tail light fuse were both blown now I guess I got to try to find out why they blew. and get my dimmer switch back in right that thing sucks horribly thanks for the help Link to comment Share on other sites More sharing options...
