Will The Tires Fit?
  • Please log in to reply
50 replies to this topic
#1 BookspanS
BookspanS
    Comanche Addict
  • Members
  • 623 posts
  • LocationNorth Charleston, SC
Posted 05 February 2014 - 07:43 PM
My dad has his factory 32x11's from his JK that he has will work for my factory 2.5. I plan on getting the lug adapters for the 4x4.5 to the 5x5 for the tires. I just need to know will my engine be able to handle the size, and will the factory height need adjustment for fitment?
'86 Jeep Comanche Custom - Pretty Much Bone Stock...For Now
*Jeeps will potentially consume all of your excess money.
*Your wife/girlfriend will get pissed because you work on your Jeep to much.
#2 onlyinajeep726
onlyinajeep726
    Comanche Fanatic
  • Members
  • 2,049 posts
  • LocationClayton, NC
Posted 05 February 2014 - 07:53 PM
That 2.5 will be gutless without a regear... And unless you want to trim the hell out of your fenders, a lift will be needed to fit that sized tire, especially since the wheel adapters will make them stick out further.
1986 Comanche Custom, 4.0L I6, AX15e manual, NP242, Open 4.10 HP D30/Ford 8.8, dual exhaust, 255/75R17 BF Goodrich M/T's, 5.5" SOA lift, etc. -- <MJ Build>
1988 Cherokee Pioneer, 4.6L I6 Stroker, AW4 automatic, NP231, Open 4.10 HP D30/Locked C8.25, 33x12.5x15 BF Goodrich A/T's, 4" lift, etc. -- <XJ Build>
Death Wobble?
Comanche Stock Specs
February 2014 MJOTM!!!
#3 HOrnbrod
HOrnbrod
    Moderator
  • Moderators
  • 17,435 posts
  • LocationSweet Home Alabama
Posted 05 February 2014 - 08:10 PM
Off Topic:   BookspanS, are you still in the Navy?
Don oo ˍˍˍọọọọ
vˍˍˍˍˍˍˍˍˍˍ_,\ˍˍˍˍˍˍ\,ˍˍˍˍˍˍˍ           Not Sent from my iPhone using Tapatalk        ROLL TIDE
/--------\_ __│     []lllllll[]
 ͞  /﴿_﴿͞ ͞ ͞ ͞ ͞͞͞͞͞͞ ͞͞ ͞͞͞  ͞͞͞͞͞ ͞  ͞/﴿_)=(﴿_﴿
1991 RedLogo.jpg Comanche HO, AW4, 2WD, HESCO 4.6 Stroker, 01 Intake, 2.5" Dual Exhaust, 62mm BBK Throttle Body
OME Suspension, 4.10 D44, 2.5" lift, WJ Rear Sway Bar, Power Everything, Ford Rear Disk Brakes, CHROME FREAK
TIP: Check out the DIY Search Index for answers to your questions & solutions for your projects.
#4 BookspanS
BookspanS
    Comanche Addict
  • Members
  • 623 posts
Thank you. That is exactly what I needed. Approx. what size lift would i need? Would a leaf relocate and 2" lift springs work? Also, referencing a regear, what gear ratio would I need to upgrade to (4.25?)
#5 BookspanS
BookspanS
    Comanche Addict
  • Members
  • 623 posts
Posted 05 February 2014 - 08:11 PM
I am not, sorry :-(. I am still in avaition though working for Boeing in Charleston, SC
#6 HOrnbrod
HOrnbrod
    Moderator
  • Moderators
  • 17,435 posts
Posted 05 February 2014 - 08:13 PM
:offtopic:   BookspanS, are you still in the Navy?
Okay, that's cool.   :thumbsup:
Don oo ˍˍˍọọọọ
#7 onlyinajeep726
onlyinajeep726
    Comanche Fanatic
  • Members
  • 2,049 posts
Posted 05 February 2014 - 08:43 PM
A 4-5" lift should suffice for that tire size.  By leaf relocate, do you mean converting the rear to spring-over-axle?  If so, that will net you a minimum of 4.5" of lift, but could be as much as 6" of lift.  As far as regearing goes, that is dependent on your transmission and current gear ratio.  If you have the AX4 4-speed, you'll likely have 3.55's.  If you have the AX5 5-speed, you'll likely have 4.10's.  If you have the TF904 3-speed automatic, you could have either 4.10's or 4.56's.  I'm not sure of the exact rule, but I've been told that for every two tire sizes you go up over stock, you want to go numerically up a gear.  So, for instance, stock sized tires are 28's, you want 32's.  If you have 3.55's now, you want to go up to 4.56's.  The stock gear ratios for the axles on our Jeeps go like this, IIRC:
  • 3.07's
  • 3.31's (rare from factory)
  • 3.55's
  • 3.73's
  • 4.10's
  • 4.56's (rare from factory)
Anything above 4.56's and you have to buy some from an aftermarket company. These are available from companies such as G2, Superior Gear, Motive Gear, etc.:
  • 4.56's
  • 4.88's
  • 5.13's
  • 5.38's
Here's some more info on the subject: http://www.alloyusa....tio-calculator/
It's should clear up any confusion, but it's not an exact science.  By the way, not all the gear ratios they have listed across the top of their chart are actually available for our Jeeps.
Death Wobble?
#8 Eagle
Eagle
    Moderator
  • Moderators
  • 11,850 posts
  • LocationConnecticut
Posted 05 February 2014 - 09:27 PM
They won't fit, and they're much too big for a 2.5L anyway. Let's assume you have 4.10 gears and a five-speed. At 60 MPH, the engine would be turning 2700 in 4th gear, and only 2000 RPM in 5th. That's WAY below the power and torque peaks for the 2.5L.
Eagle
Self-appointed President for Life of the International MJ Preservation Society
1987 MJ Pioneer 4.0L 5-speed
1988 MJ Chief 4.0L 5-speed
1988 MJ SporTruck 2.5L 4-speed
XJs -- "A few"
#9 Eagle
Eagle
    Moderator
  • Moderators
  • 11,850 posts
Posted 05 February 2014 - 09:31 PM
  • 4.56's
  • 4.88's
  • 5.13's
  • 5.38's
Last I knew, nobody offered anything steeper than 4.88 for the Dana 30 because beyond that the pinion got so small it was guaranteed to break. So 4.88 is the limit, and there's probably a reason why the factory never offered that as a ratio.
Eagle
XJs -- "A few"
#10 Rockfrog
Rockfrog
    MJ Junkie
  • Members
  • 1,135 posts
  • LocationDuncan, BC
Posted 05 February 2014 - 10:56 PM
The stock JK wheels have a deeper backspacing (6.25") than earlier jeeps. With the 1.25" spidertrax spacer adapters I used to run on the XJ the wheels were equivalent to the stock 5" bs wheels.
That said even my 4.0 had trouble turning them with stock gearing until I went to 4.56. With the 2.5 ... 4.88 would be the minimum ratio. 5.13 may prove better but would need axle swaps to accomplish.
88 Comanche, 4.0, 5spd  ...  not quite stock anymore.
00 Cherokee, 4.0, AW4 on 35's and nowhere near stock.
08 JK, the wife's new age minivan, a turd on 4 wheels
#11 onlyinajeep726
onlyinajeep726
    Comanche Fanatic
  • Members
  • 2,049 posts
Posted 06 February 2014 - 12:52 AM
  • 4.56's
  • 4.88's
  • 5.13's
  • 5.38's
While this is true, I was just trying to convey to the OP the different gear ratios that are available to answer his question in more depth.  Based on the chart, anything over 4.88's would require 35" tires or bigger, and so on, to remain optimal for MPG and power, thus leading to the necessity of swapping to stronger axles and making 5.13's, 5.38's, etc. a viable option.  But I do agree that a 4.88's+ in a D30 would not be ideal.
But to answer the OP's question, based on the chart (which is just a general idea), I'd say that 4.10's would be optimal for 32" tires.
Death Wobble?
#12 Rockfrog
Rockfrog
    MJ Junkie
  • Members
  • 1,135 posts
Posted 06 February 2014 - 08:29 AM
He had a 2.5L ... they come stock with 4.10s ... turning 28" tall tires. Put 32s on there and you'll be wanting deeper gears asap. 4.56 is as deep as I'd want to go in a D30 as you're more likely to grenade gears at 4.88. Not even going to mention the D35. You will most likely he able to live with the stock 4.10s and 32s if you stick to city driving and off road use ... but hit the highway and you're going to lose top gear. As for the charts ... they weren't designed around 5th gear ... most spec RPM/speeds at 1:1 (4th gear) and the range is usually optimal more for a V8.
#13 onlyinajeep726
onlyinajeep726
    Comanche Fanatic
  • Members
  • 2,049 posts
Posted 06 February 2014 - 08:51 AM
That's not necessarily true... His sig says he has an '86 Custom.  I have an '86 Custom that had the 2.5.  It also had the AX4 and my gears are 3.55.  If he has the AX5, then yes he would have 4.10's, TF904 3-speed auto and he could have 4.56's.  The only way to know for sure is to ask... so, BookspanS... what transmission do you have?
Death Wobble?
#14 Rockfrog
Rockfrog
    MJ Junkie
  • Members
  • 1,135 posts
Posted 06 February 2014 - 08:59 AM
OK, fair enough ... but regardless of what he does have ... anyone that's ever owned a 2.5L can agree that a gear change is needed when going up to 32s. Don't get me wrong, I'm not hating on it ... I loved my 2.5L in my old YJ ... fine motor ... but it's no torque monster or high falootin' powerhouse either.
But to the other part ... will they fit ... with minor trimming yes they will. They will rub the controll arms and in the front and rear lower edges of the wheelwells in the front. But you won't need to get all hacktastic to fit them either. The rear should sqeeze in OK though.
Which again brings us back to making them spin .... bottomline .... the 2.5L is gonna need help.
#15 onlyinajeep726
onlyinajeep726
    Comanche Fanatic
  • Members
  • 2,049 posts
Posted 06 February 2014 - 09:05 AM
I completely agree on the regear as well... The OP could swap in a 4.0 and turning them wouldn't be a big issue, hehe. :brows:   But yea, deeper gears is a must if you wish to go 32's BookspanS.
Death Wobble?
#16 ckjeep
ckjeep
    Can Spell Comanche
  • Members
  • 37 posts
  • Locationcameron nc
Posted 06 February 2014 - 10:46 AM
i wouldnt recommend it. i have a 88 jeep wrangler with the 2.5/ 5spd and 33" tires. i regeared to 4:88s and it is gutless. you can't get any lower gears for the d30 and probably shouldnt have wasted the money on the d35 lol
#17 a4xnut
a4xnut
    Comanche Fan
  • Members
  • 64 posts
  • LocationPacific Northwet
Posted 06 February 2014 - 01:21 PM
FWIW - my 86 XJ with 2.8/A904 came with 4,10's and I ran 34x9.50 TSL's without much problem... fuel economy suffered though.  Later, I went to 33x12.50 TSL's (only 0.1" shorter) and swapped in 4.56's.  It did better, but then the 2.8 isn't going to impress anyone with it's acceleration abilities.  It's got a few more HP than the 2.5, but the 2.5 has more than that difference in TQ.
Paul
89 MJ, Started life as a Pioneer, shortbox, 4.0L w/HO head, AX-15, NP231, XJ D44 rear, buckets & console
86 XJ, Laredo, 4door, 2.8 V6, A904, NP207, Scout D44 rear, high pinion D30 with Scout D44 knuckles & locking hubs, dents everywhere but the hood.
71 CJ5 project  been in the family since 1972 - in pieces
#18 benjy_26
benjy_26
    MJ Junkie
  • Members
  • 1,275 posts
  • LocationTX, 'Murica
Posted 06 February 2014 - 04:40 PM
I'm running 31's on aftermarket 15x8's on ny 87 and I rub the leading edge of the front flare when turnjng hard under full compression. I'm currently running ZJ Upcountry coils with an Energy suspensions budget boost. I got a bit over 3" over stock. The rear is stock and clears everything. If you arent afraid of a Sawzall, 32's are doable with 2-2.5". If you want to keep the body stock, I think you'll need to go over 4",I'm afraid.
87 2.5 SporTruck
AX4
31's
3" Lift
Custom Exhaust
Bedlined interior
http://comancheclub....ject-hayrunner/
#19 dasbulliwagen
dasbulliwagen
    MJ Maniac
  • Members
  • 3,263 posts
  • LocationAsheboro, NC
Posted 06 February 2014 - 08:18 PM
You guys have me discouraged now. I got a set of 5 new JK takeoffs for $200 and was planning on running them. My calculations in the past put running 32's with 4:10 gears to be nearly equivalent to having 28's with 3:55 gears. This was according to a chart I saw on here somewhere. I did recently get a set of lower profile tires to put on the JK rims if I was too disappointed by the lack of power of the 32's. I knew 31's will work relatively stock, why would 32's be that much different?
1987 Comanche Sportruck 2.5 2wd now 4wd 352,000 miles; Project: Comanche Limited
1986 Comanche X, 2.8 V6 4x4 longbed, bucket seat interior!, AC, PS, future project
1986 XJ Wagoneer 2.8 V6 auto 4x4 parts vehicle
former Jeep was 1986 Grand Wagoneer 4.2 slectrac,
1960 F100 4x4 Longbed stepside
2- Hyundai's (gotta have something reliable)
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
#20 onlyinajeep726
onlyinajeep726
    Comanche Fanatic
  • Members
  • 2,049 posts
Posted 06 February 2014 - 08:27 PM
Depending on the brand, 32's are an inch taller and an inch wider than 31's.  Turning, especially when flexed out, will rub the crap out of the fenders, especially the front, bottom.  Not only there, but the LCA's will get a good rub too.
Death Wobble?
