WRZ's comanche Now the 96 od2 swap in progress
Wrz
Knocked a few things off the to-do list, with lots of pics http://comancheclub.com/public/style_emoticons/#EMO_DIR#/smile.png
Picture of the new oil sensor installed
Removed the oil pan for a cleaning and new gasket
Before
After
Installed halfway ( have 3 broken bolts in the block, 2 from the po and one from me, still need to figure out a way to fix it )
Got my new 140amp alternator, Bought off ebay for $118 shipped, direct bolt in with no mods needs
And Installed
Fuel rail before
Wire wheel does wonders, All polished up and ready to be installed
New upgraded fuel injectors, bought off ebay for $110
Swapped and upgraded sensor fo gauge swap
Installed
Hit the valve cover with another coat of paint, Later model valve cover gasket
Upgraded the engine block ground with a taylor one, little bit of over kill but it works for me
And everything installed
Man can't wait to finish the drivetrain and get everything all bolted in so i can start on the body and axles
Waiting for my torque converter to get back from the shop, Seals are all done but apparently my converter was shot
Previous total- $1691.25
Oil sensor- $15.99
Oil pan gasket- $20.99
Alternator- $118
Injectors - $110
Temperature sensor- $15.59
Valve cover gasket- $26.39
Taylor engine ground $7.99
Cost to date- $2006.20
  • Replies 190
Engine is pretty much done for now, Just need an egr, cap & rotor, and an egr tube.
Started to prep the engine bay for paint, Would have been easier if i knew how to disconnect all the harness that go into the firewall
Think i might need some new motor mounts, what do you think lol
And some more engine bay pics
Weather permitting next weekend i will start to paint the engine bay, and monstaline the frame and under carriage
Stay tuned :popcorn:
What did you use for injectors?
Hey I bought the set off eBay for $100, they have really good reviews
Here's the link and ask him for a jeep forum discount
http://www.ebay.com/itm/Upgrade-1987-1990-Jeep-Wagoneer-4-0L-Fuel-Injectors-/281060592437?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AJeep&hash=item4170844b35&_uhb=1
  • 1 month later...
any luck on getting the egr tube on? and are those dynomax header?
The pacesetter headers are on and fit good, haven't had any luck with an egr tube, I tried to bend the original one and cracked it, think I might bend one out of copper
Motors still on the stand so cannot say ow the headers sound yet
Damn its been over a month since i last updated my build, Sadly not much progress has been made, but have ordered alot of parts for her. Havent been able to work on the comanche due to the weather and having a tenant living above the garage lol
Curently working on a few projects at the girls house
Picked up a later xj dana 30 from a 99
All the unwanted/garbage parts in a pile
Started to grind down the passenger side
Will hopefully finish grinding her down tomarrow, then a fresh coat of paint and the upgrades and installs come
stay tuned :popcorn:
Previous toal- $2006.20
Dana 30 axle - work perk :)
New total - $2006.20
with it that far apart, did you check the timing chain for slack? id have just replaced it. :)
Nice work though man. Coming out very clean.
This is the farthest I've ever gone into a motor, how hard is it to change the timing chain? And good write up or a good brand I should go with?
Thanks
Finished up sanding and painting the axle today
Inspected the gears and everything looks good
Lube Locker gasket and a nice little diff cover upgrade
Before
And installed
Got my axle u joints over the weekend
Image Not Found
Before
Image Not Found
Installed
Image Not Found
U joint install was pretty straight foward, being my first time doing this i am happy the way it all went, Only messedd up on cap, and was luck to have one of the old ones in good shape
Just waiting on my
hubs
spicer ball joints
calipers
and still shopping for a good steering set up
Previous total $2006.20
Lube Locker Gasket- $21.99
Differential cover- $62.04
Spicer u Joints-$46.00
Cost to date- $2136.23
I did mine it's pretty easy I used the Haynes book and a guy who knew what he was doin took like maybe 90 min if I remember right
thats not too bad, I'm going to have to do a little research and ill prob tackle that before i put the motor back in
Tackled the passenger side ball joints these last 2 nights, Have to say what a pittta they were, After my c clamp would not tighten anymore i ended up heating, crc freeze off and nothing did the trick, Who would have knew a few hits on the side with a hammer would have did the trick :dunno:  The drivers side should go more smoothly as i picked up a few tricks lol
Removed both ball joints
I even resulted to the grinder to help before the hammer trick
Spicer Ball joints part # 706944  Won them in a auction on ebay for cheap $30.50 shipped
( lower joint is in the process of being installed, not in picture )
No too many of the install as it was pretty straight foward
Also cleaned the inside of my axle tube, Alot of dirt and rust in there
Should have it all buttoned up and finished by the weekend
Previous total $2136.23
Passenger Spice Bal joints $30.50
Cost to date- $2166.73
finished up the drivers side tonight and started the passengers side,  will have all done this weekend
Bought some mobil one grease for the axle shaft splines
Applied to splines after a good cleaning with a wire brush and brake cleaner
Installed steering knuckle
New hub
installed
Started working on the passengers side,  had this baby out within 10 minutes
Thats all the progress i made tonight
On another note look what the brown santa finally brought me today
NOS Taiil light
With its original box
Paid a pretty penny for it, hopefully i can find the other drivers side
More pictures to come tomarrow
F$#K after posting these pictures i forgot to install the dust shield :wall:
Not the end of the world lol,, added to the todo list, and for sme reason photobucket turns my pictures :hmm:
Finished up the passengers side again, installing the dust shield this time :D
Inside of drivers axle tube  ( Before )
A little brake cleaner and a broom stick, ( After )
Some of the debris hanging around in my axle
New spicer ball joints Part # 705944
Installed
Axle shaft in place ready for hub and dust shield
New Hub
Forgot to take an installed pic
New ebc rotors  part # usr906  Scored them on ebay for $60 shipped
Installed ( Pass Side )
Installed (Drivers side)
Scored a pair of jks quick discos for $35 ( used )
And complete for now, Just need to pick install my calipers, and figure out what brand pads, and steering setup i want to go with
Weather permitting tomarrow ill get back to the engine bay and drivetrain
Previous total- $2166.73
Passengers side ball joints- $45.55
left and right hubs- $79.95
Ebc Rotors- $60 shipped
Jks Quick Discos - $35 shipped
Cost to date- $2387.23
Finally had a decent weather day today and decided to paint my engine bay finally so i can the start re-assembly. Also cleaned and painted my trans and t-case
Trans before
Cleaned and painted
Now on to the good pics :drool:
Very happy with the way the paint came out and dried, Have a few small areas to touch up, but overall was good
Plans this week are to clean/paint and change the joints in my drive shafts
Get the mtor and tanny bolted together
Check all the under hood wiring ad start re assembly
Now the fu begines
stay tuned
Looks great man. :thumbsup:  What paint did you use for the bay and fender wells? DId you do much prep?
Thanks, I used high temp engine paint on the bay and did 2 coats. As far as prep work I used grease lightening and whipped everything down the best I could, I also used the same paint on the fender braces. For the inner fender I will be using monsta liner, but I have that on the back burner till the weather breaks and I get a little more accomplished
