"too High To Get It Right" Portal Comanche
Hello, I'm from Sweden, and this is my Comanche 1988 Metric Ton.
Have rebuilt some but much work remains,
It`s a 4.0 with automatic and a Sye-kitted 231
The volvo portals are from a Volvo TGB20
Front axle are modified to driver side drop and the "flange?" redrilled to accept 5 degree caster and 10 degree uptilted pinion.
Both axle are 7.5 ratio and are vacuum locked (will proberly install 6.0 ratio later)
The plan is to have a "SNOWMonster" Arctic truck style
And now some questions:)
Does anyone have any picture on any more portalaxled Comanche?
The only one i found was this
What fender flare are the widest for comanche?
Sorry for bad english
  • Replies 122
That's a beautiful looking rig you've got. To answer your question the widest flairs I know of for the front will either be bushwackers or I think rustys off road sells some pretty wide ones too.
ive got some stock JK flares for my full width MJ and theyll be just fine. not a stock fit, and the front have a weird angle that ill have to figure out
Redrilling the housing
Did a little flextest, could probably lift 200mm more but the highlift were bottned out
has anyone come up with an effective aftermarket portal that can be used on different common axle housings??? You wouldn't think it would be too complicated...
A couple of company sells bolt on portals but i think they all cost to much to be interesting.
http://www.torqaxle....products/axles/
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
Got the brakes and vacum system completed...
Made a new heavy duty trackbar bracket with crossframe support.
Ventilation and Locker hose
Ventilation block
And the dark blue tanks are vacum storage for the lockers
The brake is finished but think i have to replace the master clinder to something bigger.
Locker controlpanel
The 12v vacum valves did get pretty hot so i installed a computer fan...
The next project will probably be a handbrake on the transfercase...
