The Family Truck
Thanks.
It's frustrating and fun at the same time.
I wish I didn't have so many other things to do. (like work) :brows:
The plan is to get it running again and on the road by the end of the summer. comanche.gif
Hopefully then finish it sometime after.
  • Replies 143
And they resurfaced this:
Not doing anything today...Have plans. Slowly but surely.
Not to poop on your parade, but did they remember that the MJ/XJ flywheel isn't flat? It has a convex or concave shape to it that it needs to retain. I forget which... Without it there are usually operational errors.
I hope the machine shop knew about this.
Rob L. :smart:
Rob L. :smart:
i was going to say something about this,
but i thought it was for the ax-15:?
Well, I didn't know about that. :doh: I don't know if they did or not. I'm guessing not.
I've searched this forum and it appears that most don't have problems if they have it done. I'm plowing forward.
If I have clutch issues, I'll know why. At least it will come apart easier the next time. :thwak:
  • 1 month later...
So, I finally got some time to work on the old mule this weekend.
I didn't take any pics, but I got the transmission bolted in. Woohoo!
Now I should be able to get back to working on it from time to time.
The tranny was holding me back as I needed help on that one. My son helped me.
On to the next item on the very long list. :wrench:
  • 1 month later...
Finally got to work on the truck again.
The daughter got married at my house so the truck got put on hold for several weeks.
Today, I bolted the cross member on the rest of the way and hooked up the front driveshaft. Had to change out the bracket that the transfer case linkage hooks to on the tranny tunnel. didn't realize that it was different for the 5 speed. So hooked the linkage up. Tried the rear driveshaft, but it is a bit too short. I'll have to have it lengthened. Put the crankshaft sensor on. Next, I'll hook the starter back up and the line between the clutch master and slave cyl.
Well, time for an update.
I got the rest of the bolts in the transmission and crossmembers.
I attached the starter.
I had to lengthen the driveshaft as it was a bit short with the tranny change. Used the cherokee driveshaft for a section.
Put new fluid in the tranny. drained the transfer case.
Put some hydraulic fluid into the clutch master cylinder. Need to bleed it. Not today, though.
Put the shifter on.
Slowly coming together.
I was going to put bucket seats and a console in it, but I'm reconsidering that. I may stick with the bench seat. Toying with the idea of putting a provision to put a wrangler seat in the bed from time to time with belts, etc. for when grandkids get a little bigger.
IT LIVES! ! ! ! !
:banana:
Thanks to a post on here, I searched and found what wires to splice to fool it into thinking the non existent auto trans is in park. :hmm:
Swapped the oil pressure sending unit from the doner so that the oil pressure guage is no longer pegged and now works properly.
Makes me happy and now the project is getting exciting again. Sounds mean with no exhaust system hooked up.
Should sound real good with the flowmaster muffler on it when I get to it.
IT LIVES! ! ! ! !
:banana:
It's a good feeling making progress isn't it? I remember when I fired mine up and moved it around after my 4wd swap and it was a great moment, and you're right. The exhaust sound with nothing hooked up is pretty menacing.
I_SGV62aoek
Making progress.
Steering wheel attached.
Starting to look like a truck again. :clapping:
Got an electrical issue that I'm going to look into :dunno: , but it starts and runs.
Hopefully, if it quits raining, I'll be able to drive it up to the barn this week.
WooHoo!
Thanks, but the FRAM is staying until the next oil change.
I have heard about them being junk, but I've used them before with no issues.
Anyway, today I got the 4wheel drive working. WoooHooo!!!!!!
The CAD was defective so I locked it in as per instructions on this site.
Looked over the electrical issues I'm having but no luck there yet.
I think I'll put the exhaust system back on next.
Well as I said, the 4X4 is working again. Modified the CAD to get the axle locked as it should be.
Today, I put on the exhaust system.
Chopped the stock muffler off and installed the Flowmaster.
Not as much rumble as I expected, but better than stock. It definitely sounds better than the straight header. :eek:
Here are some pics...
Been troubleshooting the electrical issues and found most of it.
The dash lights and parking lights were simply a fuse.
The horn, blower, lighter, radio and wipers are the ignition switch.
They work if I screw around with the key switch.
So, unfortunately I get to take the column apart again. :headpop:
Cool, didn't have to take the column apart. The switch for those of you who don't know is mounted to the top of the column back towards the firewall. Just had to take the 2 nuts out of the mounting bracket to lower the column. Then had access to the switch.
2 small bolts and done.
Now everything works except the turn signals. :clapping:
Glad I looked over the old column before diving in.
For 11 bucks, I just bought a new one instead of putting the one from the old column back in. Didn't want to take the chance that it would stop working next week. :nuts:
On to the next item on the Looooonnnnggg list.
:D
Greetings all!
I got the valve cover gasket replaced. :wrench:
Then pressure washed the engine compartment. :eek:
Wow! What a difference... :clapping:
Coming along.
Also got the clutch pedal rubber pad replaced.
Have a shifter inner boot on the way from Quadratec.
Replaced a couple of vacuum lines, swapped the whole throttle body assembly from the donor.
It didn't idle very well. I could have just swapped over the IAC, but was just as easy to swap the whole throttle body with everything attached to it. Put a new air filter in.
Still have a million things to fix and/or replace, but things are moving pretty good now...
Today I had the day off and spent it on the truck.
Got the rust cleaned off the floor boards.
Painted them with some rustoleum type paint I had around.
Cleaned the carpet.
Before:
After:
Cleaned the Seat.
Before:
After:
Fixed the interior lights.
Lastly, I got a new brake pedal cover from the local jy to match the new clutch pedal cover...
:brows:
Reassembled part of the interior this weekend.
Put in the carpet and put the seat back in.
Carpet looks a lot better, but it still has a lot of stains.
Need to get some floor mats. That will make it look a lot better.
Put in the console I scored from the JunkYard.
Looks like a truck again.
Still have a whole lot to do though...
:nuts:
No pics, but I fixed the turn signals and reinstalled the lower part of the dash.
I'll post pics of that later.
The turn signal switch just was funky so I cleaned it and they worked.
I switched the blinker for the one from the donor because it was blinking really fast.
It is normal now.
Just need to hook up the reverse lights and that will be all of the electrical work!!
Scratching things off the list... :wrench:
Got plates and insurance on the old mule and took it for a drive.
Still have some suspension stuff or steering box issues in the front. Will address in the next couple of weeks.
Good to get it on the road.
Reattached the seatbelts.
Here is a pic of the lower dash panel back on. :brows:
Picked this up at the yard. Will install soon...
Couple of pics of how it sits in the barn now.
The list is getting shorter, but it still has a lot of things on it.
:ack:
