rear disc brake conversion
  • Please log in to reply
11 replies to this topic
#1 misterroadman
misterroadman
  • Members
  • 9 posts
  • Locationnaugatuck,ct
Posted 08 January 2010 - 10:30 PM
i have a 88 Comanche with a Dana 44 in the rear. I'm looking to convert to a disc brake set up but haven't had any luck finding a kit anywhere. If anybody has any helpful info it would be appreciated.
#2 Geonovast
Geonovast
    Can NOT spell Comanche
  • Members
  • 7,087 posts
  • LocationSpringfield, MO
Posted 08 January 2010 - 10:31 PM
Grab'm off a ZJ with a 44 from a yard.
-Correy
99 XJ, 4.0 HO/AW-4/NP 231, D30/8.25 - Parked The MJs formally known as mine.
88 MJ, 2.5 TBI/AX-4, D35 - DD                             CC on Facebook!
Think of the children; Lock your CAD today!  Having trouble posting pictures?
Do I have an AX-15 or BA 10/5? What's my factory axle ratio? Common Jargon definitions.
#3 DJM/78
DJM/78
    Comanche Addict
  • Members
  • 847 posts
  • LocationColoradoSprings,CO
Posted 08 January 2010 - 10:43 PM
I'm wanting to know as well . Could you buy the parts new , from say NAPA or OEM ?
Are the parts a direct swap ? What should we look out for ?
I am doing this , or trying anyway to my 89" Dana 44 .
Dave M.
92" MJ 4x4, 4.0 HO w/ AX-15, SWB ( Pebbles )
91" MJ Sport-Truck 2x4, 2.5 w/ AX-5 , SWB ( Bam-Bam )
Build thread : viewtopic.php?f=7&t=20421
#4 mvusse
mvusse
    Obsessive Comanche Disorder
  • Members
  • 6,423 posts
  • LocationStrasburg, OH
Posted 08 January 2010 - 11:33 PM
ZJ rear disc brakes are a direct bolt on for a D35 or D44. If you enlarge the 2 3/4" center hole to 3", they will bolt to an 8.25" as well (that's what I did).
Disc brakes need more pressure than drum, so you want to replumb the rear lines using the ZJ proportioning valve as well.
The brackets and backing plates must come from a stealership or junk yard, everything else is available from parts stores.
87 Comanche Pioneer 4.0 4x4 auto, Wilbur. 7.5" lift, welded front HP D60, Sterling 10.25" rear, 37x12.50R16.5 Military Bajas on modified HMMWV double beadlocks.
87 Comanche 2.5 4x4 5 speed, The Purple People Eater, stock daily driver.
96 Cherokee Sport 4.0HO, Sparkles. 4.5" lift, 32s, 2wd converted to Selec-Trac. Built for my daughter.
#5 dasbulliwagen
dasbulliwagen
    MJ Maniac
  • Members
  • 3,260 posts
  • LocationAsheboro, NC
Posted 09 January 2010 - 12:28 AM
Wasnt there someone talking about getting rear discs for these froma crown vic? Id like to know more about that too if it is what it is.
1987 Comanche Sportruck 2.5 2wd now 4wd 352,000 miles; Project: Comanche Limited
1986 Comanche X, 2.8 V6 4x4 longbed, bucket seat interior!, AC, PS, future project
1986 XJ Wagoneer 2.8 V6 auto 4x4 parts vehicle
former Jeep was 1986 Grand Wagoneer 4.2 slectrac,
1960 F100 4x4 Longbed stepside
2- Hyundai's (gotta have something reliable)
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
#6 johnnyc
johnnyc
    Comanche Addict
  • Members
  • 951 posts
  • LocationFullerton, CA
Posted 09 January 2010 - 12:36 AM
IMO, the Explorer conversion is the easiest to obtain. There are plenty of 4-disc Explorers in the junkyards. Here's my Explorer rear disc equipped Dana 44.
Posted Image
My MJ Project
1992 Comanche
#7 LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW
    MJ Junkie
  • Members
  • 1,396 posts
  • LocationHuntington, Indiana
Posted 09 January 2010 - 10:06 AM
They are not a direct bolt on for a D44. You need to make a spacer (axle retainer) as the ZJ one is not thick enough. You'll also need to enlarge the center hole of the backing plate a bit as well for the D44.
As far as bolt-on kits available on the market; Crown as well as TeraFlex both make kits now that include everything needed and that will simply just bolt-on.
#8 DJM/78
DJM/78
    Comanche Addict
  • Members
  • 847 posts
Posted 09 January 2010 - 10:25 AM
Does that still apply to the 89" XJ dana 44 ? I am assuming they are pretty much the same . :dunno:
Thanks !
:dunce: in training !
Dave M.
#9 500 MJ
500 MJ
    Comanche Fanatic
  • Members
  • 2,696 posts
  • LocationBelleville, WI
Posted 09 January 2010 - 10:30 AM
I've done the ZJ disc conversion on my '87 XJ D44. I used the same procedure as is outlined at http://www.madxj.com There is no direct link to the page but it is under the Technical side tab and then you need to scroll down to the Brakes headliner. The writeup on how to do it is the first one. Pretty simple to do.
I had to weld some little home-made tabs on my e-brake cables to get them to work. As far as the axle seal spacers go I was able to make mine in our shop on the drill press with some hole saws and some 1/4" steel - took forever to cut them with the hole saws though...
Here are some of the pics I've got of 'em:
Posted Image
Posted Image
Posted Image
Here are the tabs I welded to the cables.
Posted Image
Posted Image
Hope that helps.
Thanks !
All years ('87-'89) XJ D44 were the same.
- Brent
'88 MJ 4wd (D30 and D44[3.55], 33", 4.0L/AX-15/231, 5" LA)
Build Thread
MJOTM January 2011
'90 MJ 2wd (D35[3.55], 4.0L/AW4)
Build Thread
"I like 10 slot grilles, '87-'90 4.0L engines, and long drives on the beach."
#10 misterroadman
misterroadman
  • Members
  • 9 posts
Posted 09 January 2010 - 06:43 PM
does the year make a difference with the ZJ or the Exploder?thanks for all the info , gotta love this forum!!!!!!!
#11 500 MJ
500 MJ
    Comanche Fanatic
  • Members
  • 2,696 posts
Posted 09 January 2010 - 06:50 PM
the stuff I got was off of a '98 ZJ dana 35. Thats all I got for ya on that one...
- Brent
Build Thread
MJOTM January 2011
Build Thread
#12 Phoenix of Fury
Phoenix of Fury
    Comanche Fan
  • Members
  • 83 posts
  • LocationDenver, CO
Posted 09 January 2010 - 07:58 PM
http://www.tsmmfg.com/ is where I got all the parts to do mine.
86' Comanche
2.5L, AX-5
30 w Truetrac, 44 w Detroit, 4.88 gears
4.5" Lift, 33"x12.50" MTZ's
